Rack and Pinion Rebuild
beemnmatt
AntiSpam:No
Post by beemnmatt » Fri Apr 30, 2010 8:19 pm
Okay, here goes the write up, e36 rack and pinion reseal
Before we start I removed the "nut and spring" that put tension on the rack shaft
1. Clean the rack!
2. Remove plastic cover on the steering spindle and remove the circle clip
3. Remove the 22mm nut on the bottom of the steering tower, and remove the inner 13mm cadmium plated lock-nut
4. Tap out the pinion gear from the bottom. At this point, steering fluid will pour out so make sure you have a catch can handy.
5. Remove the rightmost air crossover fitting from the rack (this is the one attached to the plastic hose).
6. Pry out the large metal ring from the rack through the plastic fitting's hole. Be careful not to mar the hole, otherwise the air crossover fitting may leak.
7. Tap the end of the rack that has the teeth with a hammer, be careful lots of fluid may leak out
8. You can now pull out the rack. Inspect it for corrosion, and if there is, buff it out with very fine grade sandpaper (400 grit) in a circumferential pattern
9. There are two important seals here that should be fairly straightforward to see.
This one, just get something to catch the lip, and tap with a hammer, you can see I used a breaker bar and tapped the seal out with a hammer
10. Remove the bottom bearing in the steering tower. You will now have access to the pinion ring seal. Drive this seal out and reinstall the new seal
Again, find something to catch the lip, it pops right out
11. Replace the four o-rings and 4 sealing rings on the pinion gear.
my kit came with one seal to replace the two that I removed, they are almost the same thickness
Dont forget to replace the seal attached to the rack shaft and the one that slides off the pinion shaft
12. Clean the rack and re-grease the rack. Reinstall the rack, slide the moving seal onto the rack, noting direction, then replace the end retaining ring.
13. Reassembly is pretty much the reverse of dis-assembly. Make sure to re-grease everything! (shaft and pinion)
AntiSpam:No
Re: Rack and Pinion Options
Post by M20_fever » Sat May 01, 2010 4:55 am
top notch write up, sticky for you. My only suggestion is to change the thread title so it easy to search for, like rack rebuild or something.
Post by ten2doyle102 » Mon May 10, 2010 1:01 pm
Very cool! We got a lot of good info on this site. Now we just need to get people to use it!
AntiSpam:No
Post by Yoshi » Mon May 10, 2010 2:16 pm
Dude that is fucking AWESOME! I'm so doing this soon. Thank you!
AntiSpam:No
Post by M20_fever » Mon May 10, 2010 11:40 pm
Very well done!
if you decide to continue improving this I suggest supplying part numbers and/or links to where you sourced the parts.
AntiSpam:No
Re: Rack and Pinion Rebuild
Post by Yoshi » Mon Aug 02, 2010 1:50 pm
I changed the name cuz I was looking for this and couldn't find it lol.
Where did you get the seal kit from?
joecrotch
Post by joecrotch » Wed Sep 01, 2010 3:28 am
omg i just found this.......this is a top notch sticky!
anyone ever find out where to get the seal kit?
also yosh if i was going to swap for a e36 rack would a 318ti rack work i found a re-built one for 160
AntiSpam:No
Post by Yoshi » Wed Sep 01, 2010 1:04 pm
I think any E36 rack should work.
any no, still waiting on link for the seal kit cuz I'm too lazy to look for it myself.
AntiSpam:No
Post by M20_fever » Wed Sep 01, 2010 5:58 pm
do some research before you buy that ti rack, IIRC different models of the e36 chassis came with racks with different ratios. The 318ti got the bottom of the barrel parts for everything else, I assume the rack is the least desirable. This is all speculation, which is why I suggest you do some research on your own.
joecrotch
Post by joecrotch » Thu Sep 02, 2010 3:38 am
thanks I'll poke around and report back.
acolella76
AntiSpam:No
Post by acolella76 » Wed Nov 24, 2010 4:52 am
This site is awesome!
Where did you get the seal kit? I just picked up an M3 rack that is leaking like a mofo
AntiSpam:No
Post by Yoshi » Wed Nov 24, 2010 12:55 pm
I've wanted to know this for months lol
acolella76
AntiSpam:No
Post by acolella76 » Wed Nov 24, 2010 4:14 pm
well, i did some searching. Does anyone know if the E36 M3 uses the same seals as the standard E36? Because I found this...
http://www.partsgeek.com/gbproducts/WC/ ... oogle+Base
AntiSpam:No
Post by M20_fever » Wed Nov 24, 2010 6:14 pm
Well the ratios are different, but I'm not sure on the seals.
acolella76
AntiSpam:No
Post by acolella76 » Wed Nov 24, 2010 7:45 pm
the kit i found has 24 seals, the one in the DIY has 23... seems like it would be worth it to try it out. I'll order it and let you guys know, unless anyone can confirm that it won't work
